2000 Chevy Impala car turns off without warning while drivi
JLMEXICO20022000
Engine Performance problem
2000 Chevy Impala 6 cyl Front Wheel Drive Automatic
what could the problem be if my car turns off with out any warning after about 5-10 minutes of driving and takes about 10-15 minutes to turn back on i have already changed the fuel filter and fuel pump also have taken the ignition coils to get checked along with the control module and they pass the test
Jan 12, 2010 at 7:33 AM
TOOOMANYTOYS
  • 513 POSTS
Checking modules becomes very hard when the problem is intermittent. I have run across a similiar situation and it truned out to be the ignition swith. The vehicle would need to be run with a scanner on it, and it would be necessary to record the freeze frame data when the stall occurs.
Jan 12, 2010 at 7:42 AM
TAKECHARGESARGE
  • 92 POSTS
Hi jlmexico20022002@yahoo.com,
I had the same problem with my 2000 Impala. It was as if someone would shut off the ignition switch.
It usually happened between 15 and 20 minutes during the first trip of the day and it always was able to restart after about 5 minutes of rest.
After a lot of troubleshooting, the mechanic found the Crankshaft Position Sensor was the cause. Once it was replaced, the problem went away. That was three years ago and it still hasn't returned.
TakeChargeSarge
Jan 12, 2010 at 2:15 PM
