my car shakes everytime im driving slow but when im on the highway it drives fast and just today the car said low colient
Feb 5, 2009 at 3:17 PM
✓Experienced Mechanic
Hi:
First, make sure the coolant level is full and if you need to add, use the correct type. DO NOT MIX DEXCOOL WITH ANY OTHER TYPE OF COOLANT. Also, check to see if there are any leaks and if the engine is running at a normal operating temp.
As far as the shake or wobble, is the check engine light on? Check the engine oil to see if it's appears as if coolant is getting into the oil.
Let me know what you find.
Feb 6, 2009 at 10:23 AM
NASUTE
MEMBER
For the wobbling, check your tires. My car wobbled first at slow speeds, then at every speed. Turns out, my tires were coming apart. Most tires are made in 2 parts, and if they mess up, you get the wobbling.
