2000 Chevy Impala Blower Motor Problems
86,000 MILES • 6 CYL • 2WD • AUTOMATIC
JFEMAL
I lost the first 4 speeds on my fan a couple of months ago but still had the high speed. Just a day ago the high speed quit as well. Now I have no way to defrost my windows in the Wisconsin COLD! I figure it is most likely the resistor. If so, I was told that it is located right in the blower motor unit under the gloebox. I can change it myself but would like to see a diagram of the actual unit so I know where it plugs into the unit?
Jan 31, 2008 at 1:09 PM
MASTERTECHTIM
  • 4,750 POSTS
if you look at the blower motor. the wires that go to it come from a plug inches away. that is the resistor.
Jan 31, 2008 at 1:13 PM
BMRFIXIT
  • 19,053 POSTS
[quote:6a74783a59="jfemal"]Heater problem
2000 Chevy Impala 6 cyl Two Wheel Drive Automatic 86,000 miles
I lost the first 4 speeds on my fan a couple of months ago but still had the high speed. Just a day ago the high speed quit as well. Now I have no way to defrost my windows in the Wisconsin COLD! I figure it is most likely the resistor. If so, I was told that it is located right in the blower motor unit under the gloebox. I can change it myself but would like to see a diagram of the actual unit so I know where it plugs into the unit?[/quote:6a74783a59]
check fuses and also you need a bloer motor speed resister its located beside the blower motor 5 or so wires
if fuses all good and relays place switch on high tap on motor if run replace motor too
located pasenger side under dash and clove box
