2000 Chevy Impala BLOWER MOTOR PROBLEM
48,000 MILES • 6 CYL • FWD • AUTOMATIC
JANEYLYNN
BLOWER MOTOR DOESN'T COME ON WITH THE SWITCH BUT WILL COME ON AFTER A FEW MINUTES OR NEVER....IF A RELAY PROBLEM NEED TO LOCATE TO FIX....2000 CHEVY MANUAL DOESN'T HAVE THIS REPAIR IN IT....THANKS..
Dec 30, 2009 at 4:53 AM
JDL
  • 16,098 POSTS
Welcome to the forum, I'd have to check voltage and ground at the blower motor connector, when the problem occurs. Sometimes if there is a faulty circuit or blower motor, when you hit a bump, everything starts working again. Blower motor under right side of dash, my info for getting at the blower,is very generic, not much help.
Dec 30, 2009 at 5:10 AM
TAKECHARGESARGE
  • 92 POSTS
Hi janeylynn,
I've had a similar problem with my 2000 Impala, except with mine the air conditioner and cruise control were also affected. Here's what I found out, and here's what I found that worked.
There is a multiple ground on the brake pedal frame and all these are grounded there. They say you should tighten the connection. Well, I tried it and it didn"t solve anything.
I made sure the battery had a full charge and everything came back and works as advertised.
Good luck,
TakeChargeSarge
Jan 2, 2010 at 2:24 PM
