2000 Chevy Impala AIR LOCK
105,000 MILES • 6 CYL • FWD • AUTOMATIC
K_WENDELLH
WHAT IS THE PROPER PROCEDURE TO BLEED AIR OUT OF THE COOLING SYSTEM USING THE BLEEDER SCREW IN THE THERMOSTAT HOUSINGON A 3800 V-6
Jan 16, 2008 at 1:18 PM
BMRFIXIT
  • 19,053 POSTS
[quote:ee4eba3b80="k_wendellh"]Heater problem
2000 Chevy Impala 6 cyl Front Wheel Drive Automatic 105000 miles
WHAT IS THE PROPER PROCEDURE TO BLEED AIR OUT OF THE COOLING SYSTEM USING THE BLEEDER SCREW IN THE THERMOSTAT HOUSINGON A 3800 V-6[/quote:ee4eba3b80]
open bleeder
add coolant until full
close bleeder start engine add coolant as needed
close and let it run until thermostat open and you have heat inside
car off wait to cool off open and recheck
Jan 16, 2008 at 1:34 PM
