2000 Chevy Impala
127,000 MILES • 6 CYL • FWD • AUTOMATIC
JVASQUEZ1975
NEW FUEL PUMP AND WE GOT GAS RUNNING RIGHT AND THERE IS FIRE TO THE PLUGS BUT CAR STILL WONT TURN ON WHAT ELSE CAN IT BE
Jun 27, 2010 at 7:24 PM
  • 31,937 POSTS
Start with pulling the plugs and cleaning them, also a scan to check for any unresolved fault codes, start here.
mark (mhpautos)
Jun 27, 2010 at 7:27 PM
BLUELIGHTNIN6
  • 16,542 POSTS
timing belt may have broken causing loss of cylinder compression. also make sure fuel pressure is correct amount.
  • 31,937 POSTS
In the PM you said it starts and wont keep running, so i would be checking the ECU for any unresolved fault codes next, not all codes will set a check light on.
mark (mhpautos)
Jun 27, 2010 at 7:51 PM
