2000 Chevy Impala
N_KACOR
2000 Chevy Impala
My car usually starts fine but sometimes I will turn the key and it just clicks, it does not even try and turn over at all. Sometimes it will do this for only a few minutes and sometimes half an hour. The security light will come on, too. Today though it has been hours and it is still doing it. Im open to any suggestions to fix the problem!
May 10, 2010 at 6:54 AM
DOCFIXIT
  • 18,828 POSTS
Make sure battery connections are clean and tight. If all good then most likely bad spot on starter armature and will require starter replacement.
May 10, 2010 at 8:49 AM
