2000 Chevy Impala
280,000 MILES • 6 CYL • 2WD • AUTOMATIC
JEFF HYSLOP
Chev Impala 2000 V6 3800 series. I can not find the Power Steering reservoir to check it. The book says passenger side rear of the engine. Can you help me.
updated 4/16/10
I found it. Took the back strut off and reached in. Used my wife's turkey baster to fill it. Thank goodness we did not have Turkey for Easter dinner. I am not an engineer, but a really good place for the reservoir would be on the fire wall directly above the pump.
Thanks for your help.
Jeff
Apr 5, 2010 at 4:19 AM
TAKECHARGESARGE
  • 92 POSTS
Hello Jeff,
Yes. That's exactly where the Power Steering Reservoir is located. You have to look directly below the Alternator to find it. I didn't believe that any self-respecting auto designer would hide a reservoir. I have to remove the brace from the rear of the engine compartment when I want to check mine, but that's probably because I kind of want to see where I'm putting the fluid and my arms can't get in there without blocking the view. It's almost a feel kind of thing.
Hope this helps. If I were there I'd put my hand on the reservoir for you and it still wouldn't be any easier to find or service.
Good luck,
TakeChargeSarge
Apr 13, 2010 at 3:18 PM
