2000 Chevy Impala
146,000 MILES • 6 CYL • FWD • AUTOMATIC
JAG1123
the car was a gift,im having problem were it wont start. starter,battery,alternator is good. factory radio has been replace with aftermarket radio.is it true that thats causing it not to start? i was told that the factory radio needs to be connected to its original harness but install in the trunk because the radio's wiring sends signal to ignition. please i need help i've been stranded at 1 am. until i get lucky and the car starts.
Sep 29, 2009 at 1:52 PM
LOUT5369
  • 217 POSTS
The radio has nothing to do with it,Does the motor spin over when you turn the key?if not then either the starter went or the starter relay/fuse is bad,if it does spin but won't fire,either the fuel pump went or you're losing a signal from the crank sensor. either way you have to get it to a repair shop.
Oct 3, 2009 at 5:40 AM
JAG1123
were is the crank sensor located
Oct 4, 2009 at 9:44 AM
LOUT5369
  • 217 POSTS
Depending on which motor you have,it could be behind the balancer if you have a 3.8L,If you have a 3.4 there could be 2-3 crank sensors...1- behind the balancer...2-below the intake plenum...3- on the lower r/hand side of the block.You're better off gettin it to a shop.
Oct 5, 2009 at 3:58 AM
