2000 Chevy Impala
BABYB1
2000 Chevy Impala 4 cyl
I have a 2000 Chevrolet Impala 3.4L lately my coolant has been getting flushed back out of my radiator and my car is constantly overheating. I'm trying to find out what the problem is because the coolant will not stay in the radiator.
Feb 6, 2009 at 2:22 AM
  • 110,246 POSTS
Hi:
I would start with replacing the thermostat. It is a cheap repair. Also, when replacing the coolant, make sure to us the correct type. DO NOT MIX DEXCOOL WITH ANY OTHER TYPE.
Let me know if you have questions, and if this helps.
Feb 6, 2009 at 10:12 AM
BABYB1
Ok I had did what you said and replaced the thermostat also i replaced my water pump. It's still overheating and its starting to smoke by my radiator (round top hose). Now I'm trying to figure out why it is still overheating.
Feb 12, 2009 at 1:57 PM
  • 110,246 POSTS
Hi:
With the engine cold, if you open the radiator cap and start the car, does the coolant shoot out?
Feb 13, 2009 at 4:02 AM
BABYB1
yes it is still shooting out I'm starting to think i need a new radiator
Feb 14, 2009 at 5:19 AM
  • 110,246 POSTS
Hi:
If it blows the coolant out when it's cold like it's under pressure, chances are you have a head gasket problem. What you need to do is check compression to see if one or more of the cylenders is low on compression. Go to this web site for directions.
https://www.2carpros.com/dia/how_to_check_compression.htm
Let me know what you find.
Feb 14, 2009 at 5:27 AM
