2000 Chevy Impala
RVIII
Air Conditioning problem
2000 Chevy Impala 6 cyl Two Wheel Drive Automatic
My A/C unit starts intermittently. When I start my car sometimes the a/c will not start and other times it will. As I am driving along it will come on or go off. When it is on it works fine.
Nov 8, 2008 at 4:34 AM
DENNYP
  • 1,824 POSTS
You need to have the pressure cycle switch tested for an intermittent open. If you tap on the switch and the A/C cuts out, then the switch is bad.
Nov 13, 2008 at 4:32 AM
