1998 Chevy Lumina Turn signals
52,100 MILES • 6 CYL • 2WD • AUTOMATIC
GRIMEY
My turn signals don’t work. I changed the bulbs and checked the fuse; however, I still can’t them to work. Is there some type of relay? Thank you in advance!
Jan 18, 2009 at 6:19 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
Do the bulbs light when you select the HAZARD switch?
Your flasher relay is located behind the left side of the dash.
To learn how to check your relay before replacing it, follow the link below :
https://www.2carpros.com/how_to/how_do_i_check_a_relay.htm
Post results and I will follow up.
Thanks for using 2CarPros.com !
Jan 18, 2009 at 8:11 AM
