1997 Chevy Impala feul filter
LAUGHINGBOY
Engine Performance problem
1997 Chevy Impala 6 cyl Front Wheel Drive Automatic
Can't get quick release on feul filter to release,don't know if i'm doing it right.it looks like you just pinch the plastic sleeve and you pull the metal collar off,but it wont come off.
Jul 26, 2009 at 6:55 AM
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_97_CHEVY_IMPALA_1.jpg
Does your filter look like the above picture? Did you squeeze the ears together? Sometimes I use a pair of needle-nose pliers to squeeze the ears and get the fuel line loose. It's probably best to use the proper tool. I call those fittings quick connect, If I ever get them loose, they go back together pretty quick.
Jul 26, 2009 at 7:47 AM
