1996 Chevy Impala Stalling
FUNCH
Engine Performance problem
1996 Chevy Impala V8 Two Wheel Drive Automatic 145k miles
I have a 1996 Chevy Impala SS. I recently replaced the A/C compressor, Water Pump, Passenger side Manifold Gasket, thermostat and as of recent the MAF. The problem i am having is the Car starts completely fine first thing in the morning, but once the car warms up i can hear from the exhaust that it sounds like it is missing. When i try to give the car gas it stalls. If i attempt to restart the car after it has already warmed up it will not start unless i keep my foot on the gas. I was told that it was the MAF sensor but after replacing it-it still continues to have the same problem. Any clues?
May 11, 2010 at 2:46 PM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
May 11, 2010 at 3:42 PM
