1996 Chevy Impala rear directional
1996 CHEVROLET IMPALA
150,000 MILES • V8 • 2WD • AUTOMATIC
BUZZ354
  • 5 POSTS
The passenger rear directional not functioning. Right blinker on the dash flashes rapidly. Have replaced the bulbs, And checked the rear light assembly, which worked when plugged into the driver's side.
After reading about a short in the directional switch as a posibility, I plugged a new directional switch into the wiring harness under the dash and have the same problem.
Any suggestions about this would be greatly appreciated
Oct 19, 2008 at 6:01 AM
JNOVACK
  • 723 POSTS
using a test lamp or volt meter test to see if there is power to the plug if so you need to test for ground please let me know the results and we can go further
Oct 19, 2008 at 6:54 AM
BUZZ354
  • 5 POSTS
I tested the rear right plug. Using a voltmeter at 200 ohms, the brown wire tested at .8, the dark green and light green wire tested at 0.0, the same results at the functioning drivers side rear plug. on testing all rear lights, neither the right brake light, directional nor flasher are working. the rear right tail light bulb does light. ( Same dual filament bulb.) The front right directional/flasher bulb flashes rapidly.
BTW this is a 1999 suburban, not the 96 Impala SS
Oct 20, 2008 at 6:59 AM
BUZZ354
  • 5 POSTS
The damn plug for the trailer hitch was shorted out. Thanks for the help anyway, You guys saved me a good bit of time, as the electrical system is not my forte'.
Oct 20, 2008 at 10:05 AM
