1995 Chevy Impala how to fill radiator / Impala SS
KINGWOODMAN
Engine Cooling problem
1995 Chevy Impala V8 Two Wheel Drive Automatic
how do i fill the radiator..with no cap on the radiator....the coolant does not simply drain from the reserve tank......
Aug 26, 2008 at 12:02 AM
IMPALASS
  • 3,112 POSTS
You fill it from the radiator overflow reservoir. Once filled and you start the car there is a bleeder screw on top fitting that the upper radiator hose fits on and the thermostat is under also. Once a steadily flow of fluid is coming out close it and all air should be out. I would also turn the heater on when filling.
Sep 27, 2008 at 4:56 PM
