1995 Chevy Impala engine shutsoff
197,304 MILES • V8 • 2WD • AUTOMATIC
MAXLBS01
My car drove just fine today on the way to the office. When I came out to leave it would not start, engine sounded fine just would not fire up. I let it sit for about 10 minutes and then it fired right up but would die immediately. I first thought it was not getting fuel until it fired up but then died. Now I think it is only getting enough fuel to start.
Sep 23, 2010 at 12:29 PM
  • 75,988 POSTS
Hi maxlbs01, Welcome to 2carpros and TY for the donation
Start by checking the fuel pressure if its within specs-
Fuel System Pressure should be 41.0 to 47.0 psi
With engine "OFF", ignition "ON", and the fuel pump running. Fuel system pressure with engine running at idle speed will be lower.
Sep 23, 2010 at 5:15 PM
