1995 Chevy Impala engine shuts down
182,000 MILES • V8 • 2WD • AUTOMATIC
IMPOSTR
When you start the car it will run but when the light switch is turned on the car turns off, we replaced the alternator, starter,battery and nothing worked. The alternator and starter did need replacing. When you turn off the lights te car runs??? now the illumination of the digital speedometer is off??
Dec 19, 2009 at 5:28 AM
MATHIASO
  • 1,209 POSTS
Hello impostr There may be corrosion or a short in (DRL module) connector. Sending the diagram to your email.
https://images.2carpros.com/forum/automotive_pictures/46384_Screen_2.jpg
Dec 20, 2009 at 1:53 PM
