Engine Performance problem
1995 Chevy Impala V8 Two Wheel Drive Automatic u/k miles
was driving on the highway and it stoped going so i pulled over and check the trans fluid it need a little turns out i have a small leak on the trans started it again ran good for 5 min then did not want to accelerat like normal got home checked it out in the morning herd a knocking noise /tapping noise and drove it around the block and it accrlerats but not like normal and the knocking sound goes away but when put in park or neutral it gets loud when acclerating
Apr 24, 2010 at 8:48 AM
