1995 Chevy Impala Car Problems
127,000 MILES • V8 • 2WD • AUTOMATIC
BIGMARK08
My 1995 Chevy Impala Won't Start And When It Does It Doesn't Stay Started, Also My Turn Signal Lamps Stay On All The Time And Won't Go Out Even When I Cut All The Lights Off. Also My Locks Go Crazy Making A Flicking Noise Coming From All Doors. Then When I Turn The Key Off It Locks Them And Keeps Them Locked. Also When The Key Is Turned To The On Position I Hear Something Fissing. Then When I Apply The Brakes The Fissing Gets Louder.
White Allen Chevrolet Doesn't Know Whats Wrong.
Jun 1, 2008 at 1:59 PM
2CARPRO JACK
  • 11,533 POSTS
The hissing sounds like the brake booster may be leaking. The rest of it could be a problem with a bad battery or connection.Sounds like low system voltage is causing the BCM to do those things. Does it only do these things if the car is running?
Jun 2, 2008 at 12:52 AM
