1994 Chevy Impala misses
71,000 MILES • V8 • 2WD • AUTOMATIC
BAHERMIT
94 impala ss- When it is cold, starts fine,accelerates fine but once it warms up to operating temp, any acceleration causes severe missing, to the point it might stall. no scanner codes present, new distributor, new coil, new plugs, new wires, injectors check ok, fuel pressure is 41 psi w/vacuum disconnected. Any suggestions? Thanks
Specs on Engine cold/before starting
RPM 0
Left-INT 122 Rt-INT 129
Open/Closed open Coolant 43
Left-OS2 447 Rt-OS2 434
Left BLM 128 Rt-BLM 128
A/F Learned No FT Cell 0
TBS(v) .60 Throttle 0%
Left BPW(ms) 0 Rt BPW(ms) 0
Air Flow 0 IAC Position 159
Coolant 43 MAT 42
Fan1 No Fan 2 No
MAP 27.9 MAP (v) 4.56
BARO 27.9 BARO(v) 4.56
Knock No Knock Retard 0
Spark Adv 0 Ignition(v) 11.6
CCP Duty Cycl 0 EGR Duty 0
Time 0:0 Desired Idle 3188
A/C Request No A/C CLutch Off
A/C Press 4 A/C Press(v) .24
TCC Command P1 TCC Switch Closed
Veh Speed 0
Started Vehicle
Idles Very smooth
Acceleration (in Park) Very Smooth
Transmission in (D)-Brakes on- Spins Tires
Coolant temperature 164
Idles Very smooth
Coolant temperature 183
Idles OK but feels like very slight miss
Coolant temperature 207
Idles somewhat rough
Acceleration (in Park) Initial Miss
Transmission in (D)-Brakes on- Pushing on Accelerator - Engine misses Badly- Almost stalls
RPM 743
Left-INT 123 Rt-INT 128
Open/Closed Clsd Coolant 207
Left-OS2 80-680 Rt-OS2 75-700
Left BLM 108 Rt-BLM 111
A/F Learned Yes FT Cell 16
TBS(v) .62 Throttle 0%
Left BPW(ms) 2.3 Rt BPW(ms) 2.4
Air Flow 6 IAC Position 23
Coolant 207 MAT 65
Fan1 No Fan 2 No
MAP 8.4 MAP (v) 1.02
Spark Adv 19 Ignition(v) 13.8
Time 28:41 Desired Idle 663
Veh Speed 0
May 20, 2008 at 11:00 AM
RHALL77
  • 3,361 POSTS
what is your fuel trims and temp sensor reading when this happends? are you sure you are getting injector pulse to all cyclinders when this happends?
May 21, 2008 at 2:21 AM
BAHERMIT
[quote:b6e9eb9967="rhall77"]what is your fuel trims and temp sensor reading when this happends? are you sure you are getting injector pulse to all cyclinders when this happends?[/quote:b6e9eb9967] I modified my original question and added the scanner readings- Thanks again- sorry it took so long to reply - I couldn't figure out how to reply
Jun 3, 2008 at 1:26 PM
RHALL77
  • 3,361 POSTS
did you check your injector pulse
Jun 4, 2008 at 12:10 AM
IMPALASS
  • 3,112 POSTS
I put a less expensive (not GM) on my 95 Impala SS and the spark was still coming through and arcing off of the heat shield around the plug then to the manifold. You can also take a spray bottle of water and mist in on the plug wires when running to get a spark jump. I ordered a set of plug wires (GM OEM type) and removed the metal heat shield and have never had a problem since.
Sep 27, 2008 at 5:10 PM
