1994 Chevy Impala car bad shape
BRYAN ONEAL
Engine Mechanical problem
1994 Chevy Impala V8 Two Wheel Drive Automatic
ok guys i have a 94 chevy impala with a 350 ls1 v8 engine. i was wondering what would be the best for this car an cheap on me to fix a gas leak that leaks into my oil. i would like to know how much it would cost to fix it?, would it be better to buy a gasket kit? how bad of a position im in?, would i be better off buyiing a new engine? or what i need real good details on what should be done. please give me details an cheap ways to fix my car. also thank you for your help.
Sep 17, 2010 at 3:18 PM
HMAC300
  • 48,601 POSTS
if you start the car up and only drive it a mile or 2 all the time that is probably why you have fuel in the oil. If not then your injectors may be leaking as well you'll need to get it checked out. If you only drive it a mile or two then you shold drain the oil and change filter then drive it abotu 20 miles every time you take it out.
Sep 19, 2010 at 9:35 AM
