1984 Chevy Impala hei distributor
1,300 MILES • V8 • 2WD • AUTOMATIC
THEPILEDRIVER
350 chevy engine put together for my hot rod. i've lost spark to the plugs. new malloryhei dist. how do i test the coil pack to seeif that is the problem, or could it be a bad condenser
Oct 25, 2009 at 5:29 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Pull cap off ohm test one lead on coil secondary other lead on TACH then Ground. Should have one reading infinity the other 6000-30,000 ohms. If both read infinity coli faulty. if this checks then module most likely.
Hope this helps
Thanks for donate
Oct 26, 2009 at 4:26 AM
