1978 Chevy Impala Spark plugs and distributors
94,031 MILES • V8 • 2WD • AUTOMATIC
GARFISHER
I just replaced my spark plugs and wires i got them all on and it was mis firing so i got a diagram of the firing order and set it all up right now my car will not turn over. any idea what the problem is
Nov 9, 2008 at 5:09 AM
  • 75,988 POSTS
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Nov 9, 2008 at 5:29 AM
