1968 Chevy Impala fan
68,000 MILES • V8 • 2WD • AUTOMATIC
JEZZER69
is my fan free turning win motoer is off ,if so how does it work win motoer is running, car is over heating,have antfrez in it.
Oct 16, 2008 at 3:55 PM
  • 75,988 POSTS
If you haven't change the thermostat-do so and see what happens
When the fan clutch is working properly it will freewheel after a shutdown for a few hours-when engine is at normal temperature it will resist a little when spin by hand
Could be air lock in the cooling system-try bleeding it
Always bleed air from cooling system after replacing coolant. Set heater for maximum heat. Remove radiator cap. Loosen drain plug and remove drain bolt (if equipped) from engine block. Drain coolant reservoir. Fill coolant reservoir to MAX mark with 50/50 water-coolant mixture. Loosen bleed bolt and fill radiator up to base of filler neck. Close bleed bolt when coolant flows out without bubbles. Tighten bleed bolt. With radiator cap removed, start and operate engine to normal operating temperature. Add coolant if necessary and check for leaks.
Oct 16, 2008 at 4:03 PM
