1966 Chevy Impala COMPATABILITY
HALFBREED
Brakes problem
1966 Chevy Impala V8 Two Wheel Drive Automatic
WOULD A DISC BRAKE CONVERSION KIT FOR A 1970 CHEVELLE BE COMPATABLE WITH A 1966 IMPALA?
Aug 28, 2008 at 5:54 AM
MERLIN2021
  • 17,250 POSTS
Try fitting your spindle, if that matches up to your ball joints and tie rods ok you can do it, you need to install the new proportioning valve as well, you have the single stage master, and 67 and newer has the split master, front and back on different channels. You also need new brake hoses to reach without breaking...
Aug 28, 2008 at 6:02 AM
