1963 Chevy Impala electrical fan v mechanical fan
128,000 MILES • V8 • 2WD • AUTOMATIC
JACK GIBSON
I have a 6 blade flex fan on my 63 impala (305 cid) and would like to replace it with an electrical fan. Do you recomend to push or pull the air and how many cfm would you recomend?
Aug 23, 2010 at 8:02 AM
HMAC300
  • 48,601 POSTS
any of the electric fans are good. Just hook it up with a fuse and relay so not to cause a fire. if youi have an overheat problem check your radiator/thermostat, etc.
Sep 1, 2010 at 11:29 AM
