1962 Chevy Impala idle problem
52,000 MILES • V8 • 2WD • AUTOMATIC
DUSTINMOTE
a new 4 barrel carburetor was put on my impala before i bought it, i dont think it was ever tuned. i syphined all the old gas out and put new gas in. the car starts if you choke it and runs pretty strong. as soon as the choke is disengaged the car idle drops a lot and dies. to me it seems like the idle is too high when choked, but the idle skrew is backed out all of the way. do you have any solution to this problem that im having? thanks.
dustin
Feb 19, 2010 at 10:31 PM
BASSTECH
  • 236 POSTS
yes the carb will have to be set up to the engine. There should be a choke idle adj screw, and a base idel adj screw. If you can tell me the make and model of the carb, I'm sure I can find you a diagram of the proper screws to adj on-line some where.
Feb 20, 2010 at 4:31 AM
