I will be driving and comming to a stop and right before the van comes to a complete stop.
( with very light brake pedal pressure)
I hear a noise which seems to come from the front divers side wheel. It almost seems like the ABS is engaging.
I looked at the front pads and the rotors are clean and the smooth where the pads contact the rotor. I didnt pull them apart yet. Also the pads are as thick as the rear ones.
(Note) On another vheicle I noticed this if you drive over the white street markings for cross walks when wet.
This is not the case.
I looked at the rear brakes and noticed a rust build up (aprox 1/3 of the rotor) where the break pad would contact the rotor.
I just changed the rear brakes and rotors because of the rust build up. Thinking this would have caused the noise.
It did not correct the problem.
My next thought would be to pull apart the front pads and inspect.
Is there any service bullitens or other info on this break noise.
SPONSORED LINKS
Friday, September 25th, 2009 AT 2:58 PM
