2005 Chevy Express abs brakes
2005 CHEVROLET EXPRESS
50,000 MILES • 6 CYL • 2WD • AUTOMATIC
JIM DISHMAN
at around 3 miles per hour abs ingages is there any way to turn off the abs system
Nov 20, 2008 at 5:07 AM
DENNYP
  • 1,824 POSTS
Sounds like you have a front wheel speed sensor problem. You can clean the mounting surface for the sensors on the front hubs and see if that takes care of it. You can also remove the ABS fuse in the underhood fuse panel.
Nov 20, 2008 at 11:18 AM
