2007 Chevy Express differential fluid change
62,000 MILES • V8 • 2WD • AUTOMATIC
TNMAN52
i was going to change my differential fluid the other day and saw that there's no longer a drain plug in the bottom . there's still a plug in the center to put fluid back in though. is there a way i can drain the fluid without taking off the rear plate or pulling the axil out? thank's clyde
Apr 25, 2008 at 12:16 AM
DENNYP
  • 1,824 POSTS
You have to remove the rear cover. Only use full synthetic fluid.
Apr 28, 2008 at 3:35 PM
