2005 Chevy Express water pump replacement
BWLLMS
Engine Cooling problem
2005 Chevy Express V8 Two Wheel Drive Automatic
took water pump off , found gasket w slight rust spot, replaced gasket,belts. still leaks when filling and engine stop. will replace with new pump. engine overheats, hot hose coming out the top of radiator when running, no hot air coming out of heater. how do i get coolant into heater core?
Jun 10, 2010 at 10:47 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Not sure what exactly you need help with..? Coolant should automatically flow through the heater core. One radiator hose should be hot and other cool, that means radiator is working fine. Have you replaced the pump yet to see if that cured the leak?
Jun 10, 2010 at 1:21 PM
BWLLMS
had to purge air out of heater core, replaced pump, leak stopped
Jun 10, 2010 at 5:47 PM
