2005 Chevy Express Check Engine light
107,664 MILES • V8 • 2WD • AUTOMATIC
GUNSLINGER42
Engine code check shows catalytic Converter problem. Mechanic turned light off. Said maybe just needed reset. If comes back on, then probably needs repair. Ready to trade it in. Do not want to spend a lot to fix this, if thats the problem. Is it possible to repair the converter in lieu of replacing? Possible a blown fuse in the MIL? Thanks
Oct 7, 2010 at 6:07 AM
  • 110,248 POSTS
It is a replacement. When they go bad, they melt down inside. As far as the light, has it come back on?
Oct 18, 2010 at 1:01 PM
