2004 Chevy Express OIL CHANGE LIGHT
2004 CHEVROLET EXPRESS
83,000 MILES • 6 CYL • 2WD • AUTOMATIC
MTRDUDE
  • 51 POSTS
I need to know how to reset the amber dash light staying on that signifies the oil needs changing. Also would like your opinion on the best thing to use on battery cables/cable ends/boxes after I clean all the corrosion off. I've completely cleaned them before and sprayed them with Rustoleum primer spray but the corrosion keeps coming back on everything (positive cable end only, not negative).
Dec 7, 2008 at 11:29 PM
MMPRINCE4000
  • 8,548 POSTS
Check your owners manual for the light reset procedure.
You can buy a spray protectant for the battery at most autoparts stores.
Dec 8, 2008 at 12:28 AM
MTRDUDE
  • 51 POSTS
I don't have a owners manual, do you have the procedure there?
Dec 8, 2008 at 12:03 PM
MMPRINCE4000
  • 8,548 POSTS
Not specific to this vehicle. Ask the dealer service, they should show you the procedure for free.
Dec 9, 2008 at 1:12 AM
HOGWILD99
Here is the procedure for a 2005 express..
"Put key in the ignition and turn to on postion..but do not start.,Then within 5 secs. press accelerator to the floor 3 times" Light should flash a few times then go out.
Aug 22, 2009 at 4:18 AM
