2004 Chevy Express
65,000 MILES • V8 • 2WD • AUTOMATIC
GEODA
the motor starts fine,untill a few minutes after it starts
it will only idle but will not rev up at all. I put it in gear
and it will slowly go up to about 20 to 25 mph.
after that it eventually dies. please help!!!!!!!
Jul 8, 2010 at 6:32 AM
HMAC300
  • 48,601 POSTS
check your engine vacuum, if it's low it may be a plugged converter. If it is it should be warrantied until 80,000 miles. Make sure your fuel pump has good pressure as well. it shouldb e 40 p.s.i. minimum. so it could be a clogged fuel filter causing low pressure.
Jul 26, 2010 at 12:35 PM
