2002 Chevy Express stalling
100 MILES • V8 • 2WD • AUTOMATIC
BIRDEREL
my van keeps topping for no reason. If you get it started,it stops when put in gear. Or t even stops when stopped at a light. Had it at 2 garages and no-one can find the trouble. Changed to high test. Does it in dry or wet weather.
Oct 6, 2010 at 10:31 PM
WRENCHTECH
  • 20,758 POSTS
You may have a bad IAC ( idle air control) but try cleaning the throttle body first. Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carb cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle. If it still has a problem, replace the IAC.
Oct 7, 2010 at 12:02 AM
