Misfire Detected-No EBTCM/PCM Serial Data WHAT IS THIS ?
Jul 22, 2010 at 4:40 PM
BLUELIGHTNIN6
✓Experienced Mechanic
It sounds like the PCM fuse is popped but to be sure here is a guide to help you test the fuses with the fuse locations below. I would check all the fuses BTW
