2001 Chevy Express it
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
OSCAR SALDANA
I have a no start issue on a 2001 chevy van , the fuel pressure shows 62-64 pounds with it running and with the key on it shows 45-47 pounds , with the key off it shows 0 pounds , If I hit take the air filter out and shoot some 2+2 in the air cleaner it will fire up and run perfectly until I shut it down , then I have to hit it with the 2+2 again to fire it up , there are no trouble codes in the computer and I have good fire at the plugs , any idea where to go next ?
Aug 22, 2010 at 2:55 PM
HMAC300
  • 48,601 POSTS
replace your fuel filter if you haven't already, You may have a bad pressure regulator as well. fuel pressure regulator.
Sep 17, 2010 at 10:28 AM
