2001 Chevy Express Engine stalling
78,000 MILES • V8 • 2WD • AUTOMATIC
INTERSTATE
Why does my engine idle fine, but when the accellerator is depressed about 1/4 way down the engine stalls and starts backfiring?
Yes the check engine light is on.
I have changed the fuel pump about 2 weeks ago. I had a scanner hooked up to it and it gave 4 different codes: P0102, P0171, P0174 and P0300. I noticed when I wiggle the MAP sensor the engine tries to stall at idle speeds. I just didnt want to start replacing to high dollar sensors without first knowing if this could cause the problem.
Feb 28, 2009 at 5:34 AM
DOCFIXIT
  • 18,828 POSTS
There could be several things. Is the check engine light comming on?
Feb 28, 2009 at 5:55 AM
