2001 Chevy Express changing Distributor
2001 CHEVROLET EXPRESS
ELECTROSPARK
2001 Chevy Express V8 Two Wheel Drive Automatic
How do you change the distributor? How do you set up the timing? What tools do you need to do this?
May 18, 2008 at 7:58 PM
DENNYP
  • 1,824 POSTS
remove the distributor cap. Make note of rotor position. Remove the distributor hold down bolt. Remove the distributor. Install the new distributor in the same position the old one was removed. No timing adjustment.
May 28, 2008 at 10:26 PM
