2000 Chevy Express no run condition
28,000 MILES • V8 • 2WD • AUTOMATIC
KARSQSAP
My van starts and runs buts dies immediately. I've changed the fuel pump, regulator,filter,and starter. I',m currently troubleshooting the anti-theft system tring to by-pass the system. Fuel pressure is about 46psi at start up. Have spark and no apparent air leaks. Need help!!!
Apr 26, 2010 at 4:12 PM
HMAC300
  • 48,601 POSTS
your best bet is to get a manual and touble shoot the anti theft system to make sure that is ok as well as seeing if you have any engine codes causing the problem.
May 7, 2010 at 11:33 AM
