2000 Chevy Express Fuel Pump
2000 CHEVROLET EXPRESS
THEGUTTERCO
Electrical problem
2000 Chevy Express V8 Automatic
original fuel pump stopped engaging when turning key. Replaced pump with new. worked a few times now doesn't. Tested for power to pump. seems fine. Replaced pump again along with pigtail. Still pump not engaging. Where should I look now?
Jul 3, 2008 at 2:36 PM
RAINMANN
Check the relay, the contacts could be dirty, ohm across the contacts should be less than a ohm, or just replace the relay it's cheap.
Jul 21, 2008 at 10:53 AM
