2000 Chevy Express cranks wont start
194,000 MILES • V8 • 2WD • AUTOMATIC
DENNISJ
it turns over fine it wont statr after release or key it sputters 2 or 3 times
Dec 27, 2007 at 12:01 PM
DENNYP
  • 1,824 POSTS
Check the fuel pressure. You should see around 55psi. If not, check the main harness to the fuel pump. It has a connector issue with poor connections. It is located just in front of the fuel tank. It is a large round shaped connector. Look for the connector to have a burnt wire.
Dec 29, 2007 at 4:18 AM
