1999 Chevy Express windshield wipers
125,000 MILES • V8 • 2WD • AUTOMATIC
JOHN WALUKONIS
On 1999 Chevy express van the wipers stopped working on everthing except high speed. The washers will work on high as well. The fuses are ok and there is no circuit breaker. Is this a switch problem or a control module or motor problem?
Dec 24, 2007 at 11:12 PM
MERLIN2021
  • 17,250 POSTS
Use a voltmeter and turn the wiper to low or mid setting, check for voltage at the moter connector, if it has voltage, replace motor, if not more testing of multifunction switch is needed, or a roll of the dice!
Dec 24, 2007 at 11:21 PM
