1999 Chevy Express help
188,000 MILES • V8 • 2WD • AUTOMATIC
TJBLMR4
The engine is idoling really high all the time. I changed the pvc valve but no luck. It also idols down when i pull the oil cap off like it is sucking for air. if you could help find the problem that would be great.
Mar 11, 2008 at 11:37 AM
BMRFIXIT
  • 19,053 POSTS
check engine light on ?
scan for codes
check for vacuum leaks
check intake manifold gasket
let me know
Mar 13, 2008 at 12:14 PM
