1999 Chevy Express gas gauge
1999 CHEVROLET EXPRESS
23,500 MILES • V8 • 2WD • AUTOMATIC
CHEIIBOY08
hello, hopefully you can help me. i have with the gas gauge moving where its a blur within 3/16 of inch and same time my fuel went out and replaced it and the blur is still there and van ran for a while and broke down again. when i turn the key on i don't heard pump coming on. i figured it might be the ignition module now. help.........
Jan 15, 2008 at 6:00 AM
MBECKER123
  • 5 POSTS
Try hitting the tank while someone turns the key. Give the tank a good whack when the pump should be running. If the pump runs this way you'll have to replace the pump.
My gauge also has that blur, but for well over a year now. Today my gauge showed a full tank when I ran out of gas. The pump/ sender are new with 2k miles. The gauge still had the blur but worked fine until today.
I once had a problem where the fuel filter suddenly clogged, maybe some bad gas...
Jul 4, 2010 at 5:40 AM
