1999 Chevy Express
200,000 MILES • V8 • AWD • AUTOMATIC
GERA1971
I Have A 1999 Chevy 2500 Express Van. It Was Having Problems Starting, But Would Eventually. We Were Driving On The Highway And It Hesitated When Pushing The Gas And Then Stopped All Together. I Have Replaced The Distributor/rotor With A New One, The?
Ignition coil
with a new-used one, i replaced the spark plugs and spark plug wires with new ones. I removed the fuel injector
, cleaned the tubes. It started for about 30 secs then cut off and is doing the same thing. Any suggestions?
Jan 31, 2010 at 11:06 AM
HMAC300
  • 48,601 POSTS
scan it for codes first then check your fuel pressure. it could be your fuel pump or fuel filter.
Feb 11, 2010 at 11:55 AM
HOMER1967
  • 875 POSTS
definitly check your fuel pressure and verify you have secondary spark at your spark plugs.jeff
Feb 11, 2010 at 12:18 PM
