1998 Chevy Express stalling poor engine performance
120,000 MILES • V8 • 2WD • AUTOMATIC
ANDREW.RJSE
Replaced fuel pump, filter. Had tank and injection system flushed. Still runs poorly. At the time of engine cutting out the gas gage will spike to full and the anti-lock brake light will come on.
Sep 12, 2010 at 5:22 AM
HMAC300
  • 48,601 POSTS
make sure your battery isin good shape and the connections are clean. Also make sure your main ground is clean on teh engine block.check to see if there is a vacuum leak around your map sensor and have your engine scanned as you may have a problem . If you still don't get any codes then check yoru crank and cam sensors for ohms as they may be bad. If not a pro can do this...
Sep 17, 2010 at 10:31 AM
ANDREW.RJSE
The van is repaired. The shop found a broken wiring harness holder that allowed the harness to lay against the exhaust manifold. This caused a short in the crank position sensor.
Oct 18, 2010 at 2:19 AM
HMAC300
  • 48,601 POSTS
at least you got it fixed. it always seems like soemthing stupid that makes them break down lol......thanks for letting me know
Oct 18, 2010 at 5:31 AM
