Cold Start up
110,000 MILES • V8 • 2WD • AUTOMATIC
PJMCCARL
Having cold start issues that has increased overtime, suspected low fuel pressure, start up pressure seems to be around 55lbs, will hold pressure, seems to be normal leak down once it's started. Tune up has been done, and no codes have been set off. I have read conflicting thoughts on correct start up fuel pressure. Like to get your opinion on...
1. Correct start up fuel pressure?
2. Any thoughts on possible problems?
Aug 20, 2010 at 5:37 AM
WRENCHTECH
  • 20,758 POSTS
Coolant Temperature Sensors: Some temperature sensors in the engine control system (like the coolant temperature sensor or intake air temperature sensor) provide data to the engine control module for proper cold start enrichment.
Aug 20, 2010 at 5:53 AM
PJMCCARL
I want to install a new fuel pump?
Aug 20, 2010 at 7:20 AM
WRENCHTECH
  • 20,758 POSTS
Please use this guide
FUEL PRESSURE SPECIFICATIONS
Ignition On, Engine Off
Central FI 415 - 455 kPa (60 - 66 psi)
SFI 385 - 430 kPa (56 - 62 psi)
I would say your on the right track with fuel pressure. These things won't even run under 55PSI
Aug 20, 2010 at 7:30 AM
PJMCCARL
I have a fuel gauge hook up all the time and have left overnight and start up pressure is 35, once started after 4 or 5 times of starter turnover and starts, it stays at 45. Is there a minimum pressure for this motor?
Aug 20, 2010 at 7:55 AM
WRENCHTECH
  • 20,758 POSTS
Yes, the low end of the spec is the minimum. I know these systems have no tolerance for low pressure. Like I said, many of them won't even run under 55PSI.
Aug 20, 2010 at 8:09 AM
PJMCCARL
Thanks guys, I'll replace the fuel pump and get back to o if that doesn't work.
Aug 20, 2010 at 9:20 AM
