1989 Chevy Express Coolant Leak
24,000 MILES • V8 • 2WD • AUTOMATIC
BEARKAT12
I smelled coolant coming from the engine. I looked under the hood and noticed a couple puddles of coolant and also some sopts on my driveway. One tech (#1)said it was a lower intake gasket and they could fix it. He also wanted to flush the coolant and do a injection flush with a lube and oil and fliter job. Another tech (#2) who specializes in vettes wanted to fix the intake gasket leak with new gaskets, clean the throttle body, clean the fuel rails, clean the injectors with a sonic cleaner and replace the O-rings. Both wanted to charge me the same price- My question is shouldnt I go with tech (#2) who will clean thses parts manually rather than have then flushed?? Please advise me as I know not alot about mechanic work.
Thanks
Oct 3, 2008 at 1:13 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Yes, tech 2 would be the obvious choice.
And since you already went for a 2nd diagnosis I would get a 3rd. Unless feel the 2 you went to are reputable and you trust there diagnosis.
It never hurts to get 3 or 4 different diagnosis.
Oct 3, 2008 at 8:14 AM
